TractorLinks.com
Show Parts for Model:
Re: 2N oil in radiator
soundguy
11-29-2012 06:54:29
first you need to find out if it really is oil inthe rad.
many times a blown head hasket will let oily residue from combustion into the rad.. over time it makes a sheel and can emulsify into a layer that sets on top after water flow stops.
that is quite common and can usually be detected with a compression test and leakdown test, and then a head gasket change if indicated.
there are no oil ports in the head.. so.. if it ruly is oil.. that means block issues.. and I'd look for water int he oil.. however.. keep in mind oil ressure is usually (hopefully) higher than the psi rating onthe rad cap.. so real oil in the water, but no water in the oil is still a possibility.. though with the engine pan off and a leak down tester.. you could find it.
me?
i'd do a comp test.. and then flusht he rad with a commercial flush product to cut the oil.. then refill with water and see what happens... if comp test indicates blown hg.. then repalce as indicated.. etc.
post back for more help if needed.
momac
11-29-2012 06:59:52
 Re: 2N oil in radiator in reply to soundguy, 11-29-2012 06:54:29
Thanks for the reply soundguy. As soon as I can get it home I'll get into it. Mike
soundguy
11-29-2012 11:36:37
 Re: 2N oil in radiator in reply to momac, 11-29-2012 06:59:52
post back what ya find.. we can help!
