Jimbo's 8n
Can anyone figure this out? I always turn the fuel off at the sediment bowl after use on my 50 8n. The problem is when I turn the gas on there is no fuel flow to the inline fuel filter right before the carburator. If I take the fuel line off of the filter, gas flows perfect, then I"ll hook it back up and the tractor will have no problem getting fuel as long as its running. Then when I shut it down, the fuel flow to the filter stops and I have to go thru the same process again to start it. I tried removing the gas cap thinking it might be a vacume problem but that didnt work either. Thanks to all.
