TractorLinks.com
Show Parts for Model:
Re: fuel problem
Jimbo's 8n
11-29-2012 05:31:58
Thank you!
old
11-29-2012 07:42:52
 Re: fuel problem in reply to Jimbo's 8n, 11-29-2012 05:31:58
Brake line works just fine and will cost you less then half the price of a factory type line your call. I always use brake line any more and if to long I just put a loop in it so as to dampen vibration
pconnie
11-29-2012 15:13:28
 Re: fuel problem in reply to old, 11-29-2012 07:42:52
does it take a special flare for the fittings
old
11-29-2012 18:33:11
 Re: fuel problem in reply to pconnie, 11-29-2012 15:13:28
That is why brake line works so well it is pre flared to the correct size plus it is a double flare so holds up better
soundguy
11-29-2012 14:30:00
i usually make my own too.. but for a guy needing a one time use .. e probably don't have a bending tool.. and i figured the board could use the business.. :)
old
11-29-2012 18:34:38
 Re: fuel problem in reply to soundguy, 11-29-2012 14:30:00
Bending tool??? I have never used one yet when working with brake line but yes some people can mess up a cannon ball in a swimming pool
soundguy
11-30-2012 11:35:29
 Re: fuel problem in reply to old, 11-29-2012 18:34:38
i figure if he is not stopping to read the description.. then free bending may be totally out of the question.. :)
old
11-30-2012 11:51:19
 Re: fuel problem in reply to soundguy, 11-30-2012 11:35:29
Yep last time I bent a circular bend in one I used a carb cleaner can as the form and worked just fine
Ken(Ark)
11-30-2012 12:28:30
 Re: fuel problem in reply to old, 11-30-2012 11:51:19
A power steering pump or alternator pulley makes a good shade tree bending tool .
To the original post , remove the drain plug (1/8" pipe thread ) and replace with a $3 drain cock . If a constant stream of fuel will not flow into a coffee can then you can check one part at a time until you eliminate the problem .
soundguy
11-29-2012 06:49:54
have a good one!
