TractorLinks.com
Show Parts for Model:
Re: fuel problem
Jimbo's 8n
11-29-2012 04:47:08
Thanks. I will go back to just using a fuel line. Hopefully this site sells. them. I dont think TSC has them.
Frankmn
11-29-2012 05:38:54
 Re: fuel problem in reply to Jimbo's 8n, 11-29-2012 04:47:08
I just made one out of automotive brake line
soundguy
11-29-2012 05:25:49
yes, this site has them:
For models 9N, 2N, 8N, (1939-1952).This fuel line is from sediment bowl to carburetor. Consists of: 14 inch steel tubing with two 14 inch inverted flair fittings installed. (Part No: 9N9282A) $33.06
pconnie
11-29-2012 13:26:48
 Re: fuel problem in reply to soundguy, 11-29-2012 05:25:49
just got another 8n..guy had inserted filter next to exhaust manifold...took your word fuel line needs to be 14"..went to town 30mi trip..got line ..bent the first curve ..found the line just got to edge of hood..what tractor does the 14" line fit..bout 11" short...thanks for the good advice
soundguy
11-29-2012 14:37:24
 Re: fuel problem in reply to pconnie, 11-29-2012 13:26:48
did you follow this link i sent you?
it goes right to the listing... shows 1/4" line... etc..
pconnie
11-29-2012 15:08:11
 Re: fuel problem in reply to soundguy, 11-29-2012 14:37:24
thought 14" didnt go to link till now...any idea on length
is 25" bout right
soundguy
11-29-2012 15:21:48
 Re: fuel problem in reply to pconnie, 11-29-2012 15:08:11
couldn't tell ya really.. I bend my own... though I did once buy a pre bent one.. :)
JMOR
11-29-2012 16:34:50
 Re: fuel problem in reply to soundguy, 11-29-2012 15:21:48
I'm thinking that a flaring tool to do a 14 inch double flare is pretty special!
:twisted:
soundguy
11-29-2012 16:50:04
 Re: fuel problem in reply to JMOR, 11-29-2012 16:34:50
must be hydraulic.. ;)
soundguy
11-29-2012 14:35:57
14" I don't see that? I see 1/4" line.. 1/4" flair fittings ?
it's copied right out of the parts section???
pconnie
11-29-2012 15:03:42
 Re: fuel problem in reply to soundguy, 11-29-2012 14:35:57
sorry..thought 14"instead of 1/4 inch
soundguy
11-29-2012 15:09:59
 Re: fuel problem in reply to pconnie, 11-29-2012 15:03:42
2 14" flared ends would be odd... no? :)
Jimbo's 8n
11-29-2012 05:31:58
Thank you!
old
11-29-2012 07:42:52
 Re: fuel problem in reply to Jimbo's 8n, 11-29-2012 05:31:58
Brake line works just fine and will cost you less then half the price of a factory type line your call. I always use brake line any more and if to long I just put a loop in it so as to dampen vibration
pconnie
11-29-2012 15:13:28
 Re: fuel problem in reply to old, 11-29-2012 07:42:52
does it take a special flare for the fittings
old
11-29-2012 18:33:11
 Re: fuel problem in reply to pconnie, 11-29-2012 15:13:28
That is why brake line works so well it is pre flared to the correct size plus it is a double flare so holds up better
soundguy
11-29-2012 14:30:00
i usually make my own too.. but for a guy needing a one time use .. e probably don't have a bending tool.. and i figured the board could use the business.. :)
old
11-29-2012 18:34:38
 Re: fuel problem in reply to soundguy, 11-29-2012 14:30:00
Bending tool??? I have never used one yet when working with brake line but yes some people can mess up a cannon ball in a swimming pool
soundguy
11-30-2012 11:35:29
 Re: fuel problem in reply to old, 11-29-2012 18:34:38
i figure if he is not stopping to read the description.. then free bending may be totally out of the question.. :)
old
11-30-2012 11:51:19
 Re: fuel problem in reply to soundguy, 11-30-2012 11:35:29
Yep last time I bent a circular bend in one I used a carb cleaner can as the form and worked just fine
Ken(Ark)
11-30-2012 12:28:30
 Re: fuel problem in reply to old, 11-30-2012 11:51:19
A power steering pump or alternator pulley makes a good shade tree bending tool .
To the original post , remove the drain plug (1/8" pipe thread ) and replace with a $3 drain cock . If a constant stream of fuel will not flow into a coffee can then you can check one part at a time until you eliminate the problem .
soundguy
11-29-2012 06:49:54
have a good one!
Royse
11-29-2012 05:03:41
Steel brake line works just fine.
