TractorLinks.com
Show Parts for Model:
Re: electrical
Dell (WA)
11-25-2012 20:13:29
Johnnie........you complain......."Now when I hook up the cables the starter engages and the engine turns over"........yer 8N's starter solenoid is operated by GROUNDING the little middle terminal with the BIG thumb button by the tranny shifter. You have SHORTED yer 1-wire from the starter middle terminal that goes to the BIG push button. The BIG push button is spring loaded OPEN and seldom gives problems ...but... yer starter wire is susceptible to smashing by yer BIG CLODHOPPERS as you climb up into the saddle. Usually where the #14 stranded wire goes thru the opening at the bottom of the sheet metal dash. Do I haffta tell you to inspect and replace yer starter solenoid wire??? ........Dell, yer self-appointed sparkie-meister
