TractorLinks.com
Show Parts for Model:
Re: electrical
Royse
11-25-2012 16:29:51
Spins as soon as you hook the cables up, not pushing the button?
Seen that a couple of times.
Your solenoid could be stuck, the vibration would be the contacts chattering.
See if there is a button on the bottom that you can push to engage it manually.
If so, pushing it and releasing it a few times may un-stick it.
You could also try a light rap on the side with a screwdriver handle.
That sticking could have been caused by the bad connections you fixed,
now its trying to spin as soon as you hook the cables up.
The arcing and sparking is a bad connection.
Since they were loose it probably didn't charge the battery well either, so
charging it up would probably be a good idea.
