Yesterday's Tractor Co.
Shop Now View Cart
Order Ford 9N Parts Online
Re: 9N cast iron dash, battery tray, steering column
Matt Reichenberger
11-25-2012 16:16:12
Thanks. I am an aircraft fabricator thats why I was looking for dimensions. I will most likely use a 2N battery tray and weld the cracks together.
11-25-2012 17:54:27
 Re: 9N cast iron dash, battery tray, steering column in reply to Matt Reichenberger, 11-25-2012 16:16:12
If joining dissimilar metals, like cast iron to steel, brazing is a better choice than welding. Even for joining cast iron parts together, brazing works very well. Since you have the part off the tractor, you can put the bead on the hidden side of the joint. It will make the job much easier, since you can position the parts to a comfortable spot to work.
Matt Reichenberger
11-26-2012 19:26:25
 Re: 9N cast iron dash, battery tray, steering column in reply to Jock(OR), 11-25-2012 17:54:27
thats pretty much the plan. I'll braze the cracks and bolt on a 2N battery tray. after removing the remainder of the original battery tray, but there is also a hole.
