Yesterday's Tractor Co. Compare our Prices For Parts
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Re: OT: 12v vehicle outlet/cigarrette lighter
[Show Entire Topic]  [Return to Forum]
tn8n
11-25-2012 10:16:17
32.179.105.28
easy, each charger has a fuse in it and i had 3 plugged in.
[Reply]   [No Email]
TheOldHokie
11-25-2012 10:28:34
108.22.203.30
 Re: OT: 12v vehicle outlet/cigarrette lighter in reply to tn8n, 11-25-2012 10:16:17
tn8n said: (quoted from post at 14:16:17 11/25/12) easy, each charger has a fuse in it and i had 3 plugged in.
So there is no fuse protecting the accessory circuit itself? How is the accessory strip connected to the fuse panel? Does it have a dummy fuse to plug into an empty slot? Unplug the chargers and turn on the key. What happens?
TOH
This post was edited by TheOldHokie at 10:47:03 11/25/12 3 times.
[Reply]  [No Email]
tn8n
11-25-2012 11:53:46
32.179.105.28
 Re: OT: 12v vehicle outlet/cigarrette lighter in reply to TheOldHokie, 11-25-2012 10:28:34
the accessory tap i bought has two places for a fuse on it. one is for the fuse you remove to be able to plug it in and the other is for the accessory you are adding. it didn't blow either of those, only the ones in the chargers. i finally gave up and removed the power tap and put the factory fuse back in.
now when i turn the key on, it doesn't blow any fuses or anything and everything is working fine.except for the cigarrette lighter, obviously.
[Reply]  [No Email]
TheOldHokie
11-25-2012 13:07:27
108.22.203.30
 Re: OT: 12v vehicle outlet/cigarrette lighter in reply to tn8n, 11-25-2012 11:53:46
tn8n said: (quoted from post at 15:53:46 11/25/12) the accessory tap i bought has two places for a fuse on it. one is for the fuse you remove to be able to plug it in and the other is for the accessory you are adding. it didn't blow either of those, only the ones in the chargers. i finally gave up and removed the power tap and put the factory fuse back in.
If the fuses in the new power tap do not blow then it is wired correctly and working fine. Let me see if I correctly understand your new circuit:
  1. Your new power tap is a single jack that you purchased to replace your non-working cigarette lighter.
  2. It has a fuse block that plugs into a fuse slot in your vehicles fuse panel
  3. Ther is a socket in that fuse block for the fuse that you removed from the fuse panel
  4. The new power outlet also has an inline fuse in the hot lead going to the power outlet that protects any accsessory plugged into it.
  5. When you turn on the key with nothing plugged into the new power outlet everything is fine
  6. You have a second 3 jack power tap that you originally used in the cigarette lighter to power your gadget chargers
  7. When you plug it into the new power outlet and turn on the key all three fuses in it blow but the fuses in the new power outlet are not blown
If that is accurate then your problem is almost certainly a dead short in the old 3 outlet unit or in all three of the chargers plugged into it. Are the charger fuses built into the 3 jack power strip or are they inline with each charger? Have you tested the 3 jack "power port" with nothing plugged into the jacks on it? Have you tested the 3 jack "power port" in another vehicle? Have you tested the individual gadget chargers in another vehicle?
TOH
This post was edited by TheOldHokie at 13:18:45 11/25/12 2 times.
[Reply]  [No Email]
tn8n
11-25-2012 13:23:44
32.179.105.28
 Re: OT: 12v vehicle outlet/cigarrette lighter in reply to TheOldHokie, 11-25-2012 13:07:27
you're right on all counts. i haven't been able to test them in another vehicle yet as i'm still out on the road. that's my next step though when i get home. i feel like it's got to be in the 3-outlet power port, too, i'm not sure how it didn't blow the fuse for it in the fuse box, but who knows. i guess if the chargers work in another vehicle it pretty much has to be the power port.
[Reply]  [No Email]
Royse
11-25-2012 14:48:23
69.36.49.151
 Re: OT: 12v vehicle outlet/cigarrette lighter in reply to tn8n, 11-25-2012 13:23:44
Testing the chargers in another vehicle sounds like a good next step.
I would be afraid the 3 port outlet may damage another vehicle too.
[Reply]  [No Email]
TheOldHokie
11-25-2012 14:23:31
108.22.203.30
tn8n said: (quoted from post at 17:23:44 11/25/12) you're right on all counts. i haven't been able to test them in another vehicle yet as i'm still out on the road. that's my next step though when i get home. i feel like it's got to be in the 3-outlet power port, too, i'm not sure how it didn't blow the fuse for it in the fuse box, but who knows. i guess if the chargers work in another vehicle it pretty much has to be the power port.
You have 3 individually fused loads connected in parallel and fed by a single line fuse. If the individual load fuses are lower amperage than the main line fuse it would be easy to blow them and leave the line fuse intact.
I'd also suggest you check carefully for a blown fuse somewhere in the circuit coming to the cigarette lighter - perhaps under the dash. My suspicion is your power port caused it to blow leaving the "upstream" one in the fuse panel intact and that's why it's not working.
TOH
This post was edited by TheOldHokie at 14:43:44 11/25/12.
[Reply]  [No Email]
[Show Entire Topic]     [Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
