Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: OT: 12v vehicle outlet/cigarrette lighter
Jock(OR)
11-25-2012 10:15:11
Are you sure that you got the negative wire to ground? The damage sounds like reversed polarity. The fuses should have protected the chargers if they were hooked up correctly.
Roger in Iowa
11-25-2012 10:23:23
 Re: OT: 12v vehicle outlet/cigarrette lighter in reply to Jock(OR), 11-25-2012 10:15:11
Fuses do not know polarity...
Jock(OR)
11-25-2012 14:52:51
 Re: OT: 12v vehicle outlet/cigarrette lighter in reply to Roger in Iowa, 11-25-2012 10:23:23
True, but reverse polarity applied to many solid state devices produces a failure that draws far more than the design current.
tn8n
11-25-2012 10:18:11
i thought the same thing, replaced all 3 fuses, reversed the wires and tried again, same result.
Jock(OR)
11-25-2012 15:02:37
 Re: OT: 12v vehicle outlet/cigarrette lighter in reply to tn8n, 11-25-2012 10:18:11
OK, next is to reduce the number of variables in order to determine which one is the problem.
Have you checked the system voltage? I assume that the engine was off when you had your problem. If so, what is the voltage at the battery and at the power source you tapped? If the engine was running, compare engine off voltage to engine running voltage. If more than 14.5V with the engine running, investigate that first.
If system voltage is OK, then see if hooking up the power outlet with nothing plugged in causes a problem.
If the power outlet is OK, then try one charger at a time. Try with no load on the charger, then with the device plugged in. If they work properly one at a time, add another. Repeat.
