Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: front mount dist timing revisited
Bruce (VA)
11-25-2012 07:58:32
" Would it be common to have to file the timing slot to be able to get the 1/4" measurement? "
Make sure you have the locking C clamp positioned correctly, as in the picture.
Were you able to easily tell the wide side of the tang from the narrow side?
Did you set the points gap before you set the timing?
11-25-2012 16:20:36
 Re: front mount dist timing revisited in reply to Bruce (VA), 11-25-2012 07:58:32
set points at .015 before setting timing, got new points because thought maybe the old ones were worn too much, no difference and the wide side of the engaging tang is readily noticeable, have the "C" shaped circlip installed as shown ???
11-25-2012 18:11:32
 Re: front mount dist timing revisited in reply to boler76, 11-25-2012 16:20:36
Quoting Removed, click Modern View to seeIt is imperative that you set it by rotating in correct direction. Turn in wrong direction & you can not get the desired setting.
