Yesterday's Tractor Co. Trusted Parts Supplier since 1995
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: front mount dist timing revisited
[Return to Forum]
boler76
11-25-2012 07:05:13
184.151.63.212
Would it be common to have to file the timing slot to be able to get the 1/4" measurement? To get the right timing the concave screw is now off centre of the hole, not touching but not leaving much room for the tapered spring? Maybe I have overlooked something? bearings seem OK as no visible slop ???? Thanks
[Reply]   [No Email]
Bruce (VA)
11-25-2012 07:58:32
24.125.80.178
 Re: front mount dist timing revisited in reply to boler76, 11-25-2012 07:05:13
" Would it be common to have to file the timing slot to be able to get the 1/4" measurement? "
No.
Make sure you have the locking C clamp positioned correctly, as in the picture.
Were you able to easily tell the wide side of the tang from the narrow side?
Did you set the points gap before you set the timing?
[Reply]  [No Email]
boler76
11-25-2012 16:20:36
184.151.63.212
 Re: front mount dist timing revisited in reply to Bruce (VA), 11-25-2012 07:58:32
set points at .015 before setting timing, got new points because thought maybe the old ones were worn too much, no difference and the wide side of the engaging tang is readily noticeable, have the "C" shaped circlip installed as shown ???
[Reply]  [No Email]
JMOR
11-25-2012 18:11:32
72.181.173.171
 Re: front mount dist timing revisited in reply to boler76, 11-25-2012 16:20:36
Quoting Removed, click Modern View to seeIt is imperative that you set it by rotating in correct direction. Turn in wrong direction & you can not get the desired setting.
[Reply]  [No Email]
HCooke
11-25-2012 07:57:48
70.195.64.206
Brass screw should be pretty well centered when the timing is correct. Sure you have the straight edge on the correct side of the tang??
[Reply]  [No Email]
Bruce(VA)
11-25-2012 07:59:21
24.125.80.178
 Re: front mount dist timing revisited in reply to HCooke, 11-25-2012 07:57:48
Brilliant minds think alike....... :)
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
