Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Order Ford 9N Parts Online
9N cast iron dash, battery tray, steering column
Matt Reichenberger
11-24-2012 21:23:10
I have a 41 9N with a CAST IRON one piece battery tray, dash, steering column. The battery tray area is half rusted and cracked off. Does any one have a picture with dimensions of what it used to look like or a new one?
Old weldor
11-25-2012 18:35:56
 Re: 9N cast iron dash, battery tray, steering column in reply to Matt Reichenberger, 11-24-2012 21:23:10
My 41 9 n has a cast aluminum dash.
John Smith8N
11-25-2012 14:11:01
 Re: 9N cast iron dash, battery tray, steering column in reply to Dell (WA), 11-24-2012 21:23:10
From what I can find, the one piece cast iron dash was used only a short time in 1941. You're going to have to replace it with the later 2 piece to use a replacement steel battery tray. Or find a creative welder/machinist to modify yours. The later 2 piece cast iron column with steel dash should be the easiest to find.
The upper and lower halves (column and trans shifter cover) were bolted together and the steering arm bores were then machined to size. But they aparently held a pretty close tolerance on the bore location because I've seen several mismatched sets bolted together and used without any major misalignment in the bores.
Matt Reichenberger
11-25-2012 16:16:12
 Re: 9N cast iron dash, battery tray, steering column in reply to John Smith8N, 11-25-2012 14:11:01
Thanks. I am an aircraft fabricator thats why I was looking for dimensions. I will most likely use a 2N battery tray and weld the cracks together.
Jock(OR)
11-25-2012 17:54:27
 Re: 9N cast iron dash, battery tray, steering column in reply to Matt Reichenberger, 11-25-2012 16:16:12
If joining dissimilar metals, like cast iron to steel, brazing is a better choice than welding. Even for joining cast iron parts together, brazing works very well. Since you have the part off the tractor, you can put the bead on the hidden side of the joint. It will make the job much easier, since you can position the parts to a comfortable spot to work.
Matt Reichenberger
11-26-2012 19:26:25
 Re: 9N cast iron dash, battery tray, steering column in reply to Jock(OR), 11-25-2012 17:54:27
thats pretty much the plan. I'll braze the cracks and bolt on a 2N battery tray. after removing the remainder of the original battery tray, but there is also a hole.
Jock(OR)
11-25-2012 10:20:22
This brings up a question for the experts: Were the upper steering housings bored after assembly to the lower housings? Or were the tolerances big enough that they are interchangable?
Matt Reichenberger
11-25-2012 09:42:16
Here are some pictures of the dash.
HCooke
11-25-2012 07:59:05
I have a '41 dash out of cast aluminum. It is available to a good home. Send email.
Matt Reichenberger
11-25-2012 08:44:49
 Re: 9N cast iron dash, battery tray, steering column in reply to HCooke, 11-25-2012 07:59:05
mr5402@msn.com
Ultradog MN
11-25-2012 06:37:38
Are you certain it is cast iron?
Put a magnet on it to see if it sticks?
I know the early 9Ns had cast aluminum dashs which would look similar but didn't know they made them cast iron.
Matt Reichenberger
11-25-2012 08:43:02
 Re: 9N cast iron dash, battery tray, steering column in reply to Ultradog MN, 11-25-2012 06:37:38
Yes I a positive it is not aluminum. The magnet stuck. That was the first thing I did.
