Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Carb sosking -What fluid?
rustyfarmall
11-24-2012 06:33:02
I wonder if the float in that carburetor is made of brass, or if it is one of those composite materials? Either way, the float could be bad, but those composite floats had a tendency to become porous and actually soak up gasoline, which made them too heavy to float. A float that does not float will seriously effect the miles per gallon, and might even cause the raw gas smell you are experiencing.
A basic carb kit with gaskets, new needle valve and seat, and a new float should cure it.
A can of aerosol carb cleaner will probably take care of the crud and grime.
Joe)NYC)
11-28-2012 18:46:19
 Re: Carb sosking -What fluid? in reply to rustyfarmall, 11-24-2012 06:33:02
Thanks for the comeback. I think that is what I will wind up doing if the weather doesn't get too cold.
