Worth the money? If bought a sherman and some of the other parts I need I would have my money back. Wife says it is just more junk sitting around the place. It is close to my and I did go look at it. Looks to be original
Ebay 8N
If the Sherman is in working condition it is worth $700 or so. If the engine isn't stuck you can probably get it running. I would say it's worth $1000.
That looks like a Sherman Combo, that may make it worth it.
It can be hard to tell from pictures.
If you're going to use the tractor you may be looking at spending some money
on rear tires, they look pretty well weather cracked.
From the grease on the rear hubs it may be leaking some from the axle seals too.
The trip bucket loaders are hard to sell in my area, but the pump and spool valve are pricey.
If I needed/wanted the Sherman and it works, you could probably swap your trans,
get it running and sell it for enough to have a free Sherman minus labor.
Just my two cents.
I'm not sure but if I am right that don't look to be a sherman Hi Low.Others can verify. If it is I would buy it in a minute. I sold a sherman Hi low a few years ago for $1026.00 Cdn. Had 2 guys fighting over it. Winner took all.
