******OTOTOT******
Fellers, I have an 89 metro 3cyl., really like the
car. It didn't start one wet morning, has
happened bofore, chalked it up to dampness, after
better weather, time, ~fires and tries to start,
but not quite able to run, had been misfiring once
and a while for the past couple or three weeks. I
have been advised it is probably da Ignition
Module.
Cheapest IM on the web so far is $160, expensive.
Did I mention I am cheap?
Can't think of a 3 cyl w/points, but there are
some V6s and I could grind of every other cam lobe
and bingo, 3 cyl. breaker point distributor.
Machine a tang and fab up a bracket, some duck
tape and ...
I will probably go out when it stops raining and
move the thing into the shop, take off the IM and
have it tested.
Any thoughts? Disti fabers?
Module.
tape and ...
have it tested.
