TractorLinks.com
Show Parts for Model:
Re: How to tell if it's charging?
JMOR
11-19-2012 08:56:54
Quoting Removed, click Modern View to seePaul, that all adds up to not charging. You can jumper to polarize and after that doesn't make any difference, then you can try adding jumpers from Field to Ground and a second from BAT to ARM to connect generator to battery as well as provide maximum field current in generator, enabling it to produce its maximum output, assuming it is a working generator. If you can make it charge with the two jumpers in place, then it means generator OK, but VR bad. Be sure to remove BAT to ARM jumper when test ends/engine stops.
