I have a 48N runs fine for about 5 minutes, misses once, then about 10 seconds later, she stalls out. I"ve checked gas flow at the bottom of the carb, I have good flow (I let about a quart drain out). I also jumped the ignition switch (ran her without a key), she still stalled. I have a healthy spark over a WIDE gap on a test plug, and the front mount coil is cold to the touch. I thought I just fixed the problem by replacing the condenser, it was the only thing I could blame at this point, but I still have the same problem.
The really strange thing is that IMMEDIATELY after stalling, I can re-start her right up... I"m talking within 2 seconds of stalling.... then she will run for another 5 minutes or so then stall again…..
Can anybody offer any advice please?
Thank You
Thank You
