TractorLinks.com
Show Parts for Model:
Re: How to tell if it's charging?
Paul in Edmonton
11-16-2012 12:39:11
Bruce,
The meter works both ways--it reads positive if electrons are flowing in one direction and negative if they are flowing in the other.
Assume that normally, the electrons flow from the terminal block to the ammeter and then to the solenoid, and that's a positive reading (I may have it backwards, but it doesn't matter for the sake of the argument). If it's wired so the wire goes through the loop left to right, the ammeter shows positive. If I rewire it so it goes through right to left, the ammeter "sees" the electrons moving the other way, and will read negative, even though the wire itself still has the electrons moving the same way.
Do you have a clamp-on DC ammeter? (I do--very useful device!) If so, clamp it on a cable with DC current and take a reading. Then unclamp it, flip it over so it's facing the other way, reclamp it and take another reading--it will be negative if the first was positive. This is the same effect.
To paraphrase a common poster here: It's the Law--Faraday's Law and Lenz's Law, working together in this case...
-Paul
Bruce (VA)
11-16-2012 16:33:54
 Re: How to tell if it's charging? in reply to Paul in Edmonton, 11-16-2012 12:39:11
" The meter works both ways--it reads positive if electrons are flowing in one direction and negative if they are flowing in the other."
Ahh yea, I know that.
My point was you can not have it wired correctly w/ the correct polarity and have the wire "......going through the loop the wrong direction".
I read what you wrote literally. It's impossible to have it connected at the starter switch & terminal block and then run it incorrectly through the loop on the ammeter.
So, were all clear now!
Tnx
