Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: How to tell if it's charging?
HCooke
11-16-2012 11:59:22
The current flows one way, the needle deflects one way, if the current reverses, the needle deflects the other way. Maybe I'm wrong but I know I've reversed it on a 9N.
Bruce (VA)
11-16-2012 12:06:43
 Re: How to tell if it's charging? in reply to HCooke, 11-16-2012 11:59:22
Well yea, if you reverse the current (as old said) it will read backwards.
But if it's a loop meter & one end of the wire is on the terminal block & the other is on the solenoid, it's not 'reversible'!
On a 9N.....it goes to the hot side of the starter switch, right?
HCooke
11-16-2012 14:59:17
 Re: How to tell if it's charging? in reply to Bruce (VA), 11-16-2012 12:06:43
Sorry been away from the computer a couple of hours. It goes from the hot side of the starter switch thru the amp meter to the hot terminal on the resistor block. If you re wire it so it goes from right to left instead of left to right (thru the loop)it will be reversed.
