Yesterday's Tractor Co. Fast, Friendly Parts Service
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Re: How to tell if it's charging?
[Show Entire Topic]  [Return to Forum]
Bruce (VA)
11-16-2012 10:31:13
24.125.80.178
" If the wire is going through the loop the wrong direction, the gauge will read plus when it should be minus and vice versa. "
Huh?
It's a loop.
It can't go in the wrong direction because the ends of the wire are still attached to the correct terminals. The wire goes from point A thru the loop on the ammeter to point B.
How could that possibly read backwards?
[Reply]   [No Email]
HCooke
11-16-2012 11:15:09
70.195.64.31
 Re: How to tell if it's charging? in reply to Bruce (VA), 11-16-2012 10:31:13
Pretty sure (I have 3 or 4 of em) that you can go thru the loop the wrong way.
[Reply]  [No Email]
Bruce (VA)
11-16-2012 11:35:40
24.125.80.178
 Re: How to tell if it's charging? in reply to HCooke, 11-16-2012 11:15:09
Maybe I'm having a CRS moment.
On an 8N, point A is the solenoid. Point B is the terminal block. The wire goes from the solenoid through the loop on the meter to the terminal block. Or, vice-versa.....doesn't matter.
How can it go through the loop backwards?
CRS moment?!
[Reply]  [No Email]
HCooke
11-16-2012 11:59:22
70.195.65.211
 Re: How to tell if it's charging? in reply to Bruce (VA), 11-16-2012 11:35:40
The current flows one way, the needle deflects one way, if the current reverses, the needle deflects the other way. Maybe I'm wrong but I know I've reversed it on a 9N.
[Reply]  [No Email]
Bruce (VA)
11-16-2012 12:06:43
24.125.80.178
 Re: How to tell if it's charging? in reply to HCooke, 11-16-2012 11:59:22
Well yea, if you reverse the current (as old said) it will read backwards.
But if it's a loop meter & one end of the wire is on the terminal block & the other is on the solenoid, it's not 'reversible'!
On a 9N.....it goes to the hot side of the starter switch, right?
[Reply]  [No Email]
HCooke
11-16-2012 14:59:17
70.195.64.176
 Re: How to tell if it's charging? in reply to Bruce (VA), 11-16-2012 12:06:43
Sorry been away from the computer a couple of hours. It goes from the hot side of the starter switch thru the amp meter to the hot terminal on the resistor block. If you re wire it so it goes from right to left instead of left to right (thru the loop)it will be reversed.
[Reply]  [No Email]
old
11-16-2012 11:13:00
209.86.226.32
Bruce if you think about it for a moment you would see that he probably has the battery wired back wards as in - ground so yep the amp gauge would in fact read back wards. My Oliver 77 is that way and has been since I got ti but I know the alternator works just fine so I have not changed it since I know it is wired back wards so his tractor probably has the same problem
[Reply]  [No Email]
[Show Entire Topic]     [Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
