TractorLinks.com
Show Parts for Model:
Re: How to tell if it's charging?
old
11-16-2012 08:03:33
Digital meters do not like the engine spark noise and have that problem. Best to use an analog type meter which you can buy at radio shack for around $10 or so. You can also go buy a simple dash type volt meter and hook it to the battery and check with it not running then with it running. Not running with 6 volts you should get around 6.3 volts running you should see 7 plus. DO NOT pull one battery cable off with it running to check because you can/will let the smoke out of the charging system and you can also get hurt if you do something wrong as in maybe even dead
