Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: No oil to rocker arm shaft top for valve tappets
Den N Ms
11-15-2012 19:31:58
Did it have new cam bearings installed in the block?If it did maybe the hole in the center cam bearing is not lined up correctly.Are all the galley plugs put back in the block? It takes a little run time for the oil to get to the rocker shaft.If I remember the center cam journal has a slot in it for oiling the rocker shaft. If it has good oil pressure when running,use a oil squirt can to oil the rocker arms and push rods while letting the engine run awhile so see if it will start oiling the rocker shaft.
ZANE
11-16-2012 05:45:30
 Re: No oil to rocker arm shaft top for valve tappets in reply to Den N Ms, 11-15-2012 19:31:58
There are no cam bushings in a 134 ci engine in the Ford tractor
I suspect that the bottom of the oil tube is not in the hole in the oil gallery down on the block over the camshaft.
Even when everything is installed correctly the oil supply to the rocker arms is a pulsating supply because the oil only gets into the tube when the cam shaft turns to the place with the oil gallery lined up with the hole in the block.
I would try blowing through the tube with air and also make sure the opening in the oil gallery is not blocked by crud.
Zane
Den N Ms
11-16-2012 08:06:43
 Re: No oil to rocker arm shaft top for valve tappets in reply to ZANE, 11-16-2012 05:45:30
There are no cam bushings in a 134 ci engine in the Ford tractor.
I know that they did not come with cam bearings,but It could have them now after 59 years and numerous rebuilds.
ZANE
11-17-2012 18:04:12
 Re: No oil to rocker arm shaft top for valve tappets in reply to Den N Ms, 11-16-2012 08:06:43
I've been working on Ford tractors since I was 15 years old and have never seen one with cam bearings new or old???? I am now 77.
Zane
Copyright © 1997-2015 Yesterday's Tractor Co.
