jimnpgh
New User
how do i install dual wheels on my 860, what parts do i need? my tires are loaded and have pie weights on them, but i have lots of hills and need stability. besides tires, rims centers.thanks
You can install OEM style duals if you can find a set of the dual wheel adapters and required lug stud extenders. Besides rins and tires, you will also need another set of wheel centers for this option.
Alternatively, you can install clamp on duals. This set up requires the spacer drum and clamps but does not need wheel centers.
I have steep ground and multiple sets of OEM dual wheel adapters but never need duals for stability with any of my vintage Fords.
Dean
There are more them one type of duals. I have a set that I have not used in at least 15 years because I do not need them. My dad on the other hand had to have them, or he would get stuck in the creek. The ones I have are clap on type as in have a ring that sits just inside the lip of the rim then you have a set of brake over claps that hold them on
