Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: 2n help - no gears
11-15-2012 12:21:34
May be as simple as checking the hydraulic fluid level to be sure you are not low. It otherwise could be internal for the tranny,..stuck clutch? Bad valve in the hydraulic system? You may end up taking off the top cover to see what"s wrong.
11-15-2012 13:54:15
 Re: 2n help - no gears in reply to LeoinMI, 11-15-2012 12:21:34
no gears and no hyds DEFFINATELY points to an early drive train failure.
as JS said. I'd check any pre trans to see if in gear.. that then clutch hub.. or input shaft.
