TractorLinks.com
Show Parts for Model:
Re: right rear axel leaking
John Smith8N
11-15-2012 08:57:39
Have you ever replaced or repacked front wheel bearings on a car or tractor? The bearings in the front hub are 2 tapered roller bearings facing each other. You tighten the nut on the spindle so that the wheel cannot wobble, but not so tight that it's hard to turn and would get hot from too much "preload". You don't want it tight, and you don't want it loose. You feel for that "just right" amount then install the cotter pin.
The rear axle assembly has 2 tapered bearings also, one on each outboard end of the axles. The axles butt together in the middle. On this application you don't have a nut to tighten or loosen to set the bearing preload on the axles. You have to add or remove shims to get the correct feel. More time consuming, but the same principle.
