Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Electronic Ignition starting problem
JMOR
11-13-2012 07:18:56
HeyObie said: (quoted from post at 11:05:20 11/13/12) Hobo,
Let me get this straight. If I am standing at the
FRONT of the 8N looking at the ballast, you are
saying, run a wire from the top of the coil to the
LEFT post of the ballast. On that same LEFT post,
run a wire to GROUND.
Obie
No, that isn't what he said. To re-work your statement, he said,
"If I am standing at the
LEFT post of the ballast. On the RIGHT post,
run a wire to GROUND". NOW, let me add MORE. At this point, you have not even established that the EI/coil/spark is your problem, sooooo, the FIRST order of business is to determine whether of not you have a spark at that moment when the tractor won't start. Pull a plug wire, hold it near grounded metal parts & look to see if a quality spark is present or not. Go from there.
IF you do determine that under 'no start' conditions that you do not have a spark, I suggest that you measure the coil primary resistance. Coils vary (maybe 0.5 to 2.5 Ohms) and Pertronix recommends that combined coil + any ballast resistance add up to a total of 1.5 Ohms for your 6v system. That may mean that a resistor is needed and it may mean that no resistor is needed......it depends on that primary resistance number.
This post was edited by JMOR at 07:27:20 11/13/12.
