Yesterday's Tractor Co.
Shop Now View Cart
Order Ford 8N Parts Online
Re: 8N rear axel shaft nut torque
Dell (WA)
11-12-2012 01:53:29
Marty.........the BIG axle NUT of the 8N is supposed to be torqued to 400ft/lbs. Thatza BIG GRUNT onna 4-ft cheater bar. You can NOT over tighten yer 2"-NUT. The threaded axle end will bottom out first. To check, rock yer ag-bar tire sidewize and watch yer BIG WASHER fer movement. Iff'n you have movement, you will need to renew yer slotted hub. Iff'n yer sphincterly challenged, rent a 600ft/lb torque wrench. ........tightjaws Dell
11-13-2012 21:40:06
 Re: 8N rear axel shaft nut torque in reply to Dell (WA), 11-12-2012 01:53:29
removed the 2" nut today
It was only torqued to about 20 ft-lb. ,got lucky
Do not understand the purpose of that spring clip?
