TractorLinks.com
Order Ford 8N Parts Online
Re: 9v Battery for 8N
1951 8N
11-11-2012 19:16:10
equeen said: Okay, if I attach a long heavy cable to my 6v 650CCA or such tractor battery and trim the shielding off the other end to fit my hand.........then attach a long heavy cable to the starter solenoid and trim the shielding off the other end to fit may hand.............
Then have someone turn on the ignition switch as I hold the naked cable ends - one in each hand...
will there be more than enough amps passing thru my body to guarantee that body burial will follow?
Ouch, fellers, this IS getting scary.
You cannot get shocked from a 12 volt battery let alone a 6 volt battery.
This post was edited by 1951 8N at 19:16:41 11/11/12.
pconnieks
11-12-2012 08:46:18
 Re: 9v Battery for 8N in reply to 1951 8N, 11-11-2012 19:16:10
think not..touch the end of your tongue to the posts of a little 9volt batt. this is what i would consider a shock..its also a good way to tell if the batt.is good
