| Ford 9N, 2N & 8N Discussion Forum |
Topic: 53 Jube no spark update
[Return to Forum]
| Author |
[Modern View]
| William Fissell
11-11-2012 15:01:36
76.18.178.56
For those who didn't read the prior thread: 6V, pos ground, suddenly no spark after dead battery. Following sounder's advice: jumper from neg of battery to batt side of coil. Spark plug connected directly to wire from coil (no dizzy) and body of spark plug grounded via jumper cables to (+) on battery. Grounding the dizzy side of the coil -> weak blue spark on the spark plug then fat orange spark when I unground the coil. What I'd expect, except wimpy spark. Interestingly, if I do it again, a moment later -> no spark at all on the spark plug. but I still get the fat orange spark. If I wait for 5-10 min, I get the weak blue spark again. I assume I should be able to just zap zap zap zap zap until I get bored of it, no? This I think makes the coil the suspect. However... will get a new ignition switch anyway as its likely original and likely to be flaky. anything else I am missing? |
| JEK1
11-12-2012 09:00:35
71.214.9.132
Re: 53 Jube no spark update in reply to William Fissell, 11-11-2012 15:01:36
| | That very same thing was happening to my 8n side mount distributor tractor. All of the electrical checks were OK. It turned out that that terminal stud located on the exterior of the distributor where the wire is hooked from the coil was shorting to ground. When the terminal nut gets torqued, the insulation gets sheared. The insulation is made from gasket like material. I made one from plastic from the top of an aerosol can. The tractor now starts Oh so much better with a rich spark. |
| oldcase
11-12-2012 08:50:44
166.147.89.143
| Don't forget about the ballast resister between the ignition switch and the coil. They are notorious for causing the no spark condition you describe. |
| soundguy
11-12-2012 11:26:38
184.247.62.66
Re: 53 Jube no spark update in reply to oldcase, 11-12-2012 08:50:44
| there is no ballast resistor on a 6v/53 setup |
| old
11-11-2012 16:05:56
209.86.226.40
| Sounds like and from what you typed here that your way over thinking a very simple ignition system. You have a battery which in turns powers the system by way of a switch and a wire from that going to the coil which then in turn is hooked to the points which when they open cause a spark to the plugs. A simple hot wire from the ignition side of the battery as in none ground side to the ignition side of the coil as in non- point side of the coil will tell you if the problem is in the distributor or the system back to the battery including the switch |
| William Fissell
11-11-2012 17:30:01
76.18.178.56
Re: 53 Jube no spark update in reply to old, 11-11-2012 16:05:56
| | Thanks, old- I did that - no spark grounded the points side of the coil for a second- weak blue spark. did it again. no spark. |
| soundguy
11-12-2012 07:04:45
184.246.234.190
Re: 53 Jube no spark update in reply to William Fissell, 11-11-2012 17:30:01
| if you have hot wired the primary of the coil, disconnected the coil from the dizzy and are grounding it's primary on and off.. and it's not throwing a spark.. I'd swap a coil from another machine and check |
| William Fissell
11-12-2012 07:12:21
129.59.115.13
Re: 53 Jube no spark update in reply to soundguy, 11-12-2012 07:04:45
| | yup. that's where I am at. Will do. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
