Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: 2N Runs bad
Dell (WA)
11-11-2012 11:58:03
Flembo........the carb tweek-ums in the FO-4 are NOT even close. Set the down-pointing mainjet to 2-turns and LEAVE-IT!!! Set the side-pointing idlemix to about 1/4-turn and starter up. When warm, adjust the side-pointing idlemix for FASTEST idle NOT SMOOTHEST idle. Understand the difference???
NEW sparkies ALWAYS start eazier. While Champion H10C are equivalent to the original H-10's, AutoLite 437's are better as they self-clean the center insulator better. ........Dell, yer self-appointed sparkie-meister
flembo
11-11-2012 12:39:43
 Re: 2N Runs bad in reply to Dell (WA), 11-11-2012 11:58:03
Thanks Dell as far as the plugs go I will pick up a new set of al437s tomorow and try them. right now the main jet is set at two turns and I will revisit the idle mix as you suggest. also I didn't mention I checked spark at # 3 and 4 with plug set at 3/16 gap good strong spark. Thanks again. Don
Bruce (VA)
11-11-2012 12:54:07
 Re: 2N Runs bad in reply to flembo, 11-11-2012 12:39:43
Next time it stops, check quickly for fuel then spark. When I say quickly, I mean get off the seat, grab the tools & do it right then. Do not wait a minute or two.
You still do not know if you have a spark or fuel problem.
While new plugs won't hurt a thing & adjusting the carb is needed anyway, you probably won't fix it.
So be prepared to check spark & fuel as soon as it stops running.
And get a plug checker when you go to buy the new plugs.
When you adjust the carb, make sure the tractor is at operating temp; that usually takes 10 15 minutes at idle depending on ambient temp.
Both Ford and Marvel/Schebler (assuming you have a M/S carb ) say to set both the side-pointing idlemix and the down-pointing mainjet to 1-turn as a starting point. I set the down-pointing mainjet to 1-1/2 turns and don't fool w/ it until the final step.
Then adjust the side-pointing idlemix for fastest idle; not the smoothest idle. Next, adjust the behind the carb idle-speed set-screw for very slow 400-rpms idle. Do that idlemix adjust for maximum idle at least 3-times. Make sure that you turn the screws slowly, like 1/8 of a turn at a time & wait a second or two for the engine to catch up. Take your time!
Do it like this:
1. Adjust idle mix jet until RPM increases
2. Adjust idle-mix set screw until the engine nearly stops (as slow as you can get it unless you have a tach that tells you 400 rpm)
Repeat steps 1 - 3 three times.
Remember the side-pointing idlemix is out for lean, in for rich.
If you do not have any problems inside the carb, it is easy to get the idle down to 350 - 400 rpms.
Your last step is to go back to the main jet. Remember, in for lean, out for rich. If you end up turning it OUT more than turn for max power (remember, you already had it 1 turns out) then stop right there because you have a dirty carb or a fuel problem.
Copyright © 1997-2015 Yesterday's Tractor Co.
