| Ford 9N, 2N & 8N Discussion Forum |
Topic: Frosty carb-
[Return to Forum]
| Author |
[Modern View]
| Mr. T. Minnesota
11-11-2012 07:58:30
68.170.114.158
Have noticed my 8N carb frosting up a bit the past few weeks on cooler days. I expect it to frost up today because it will not get above 32 degrees. It eventually goes away. Did not notice this on the 2N. Could this be because of the different kind of carb on the 8N? Any thoughts are welcome. Happy Veteran's Day to all the Vets!! Mr. T. Minnesota |
[Reply] [No Email] | |
| Jerry/MT
11-12-2012 17:49:05
206.183.116.145
Re: Frosty carb- in reply to Mr. T. Minnesota, 11-11-2012 07:58:30
| | It"s normal. The evaporation of fuel in the carb cools the mixture and below ~ 50 °F, and if the humidity is high enough, the wall temperature in the carb will drop below freezing and exterior frost can be seen. Frost can also form in carb venturi (from the humid air), and over the transition port and butterfly and mess up the mixture control. It might run ratty until the manifold heats up enough to prevent this. It"s a problem with leaner mixtures so Detroit added the heated intakes on engines in the late "60"s and early "70"s when the first emmission controls came in on cars. Adding Heet additive to the fuel will not prevent this only a heated intake will. That"s why aircraft engines have carb heat. It"s obviously more critical for them. |
| duey
11-12-2012 16:40:01
99.112.81.7
| | Carburated airplane engines have a method to cause the carburetor to draw in heated air... the control knob is called... CARB HEAT!! The process of fuel atomization can cause the fuel/air mixture temperature to drop as much as 100 degrees. So you might imagine there is a wide range of ambient temps where carb icing may occur. Ice formation INSIDE the carb usually causes a rich mixture.... and can get so rich the engine dies. This often causes distress for PILOTS... and can irritate tractor drivers, too. :-) |
| old
11-11-2012 15:19:25
209.86.226.40
| Would you believe if it did not happen then the carb is not working as it should. Simple fact is that as the gas gets atomized it also gets very cold so yep the carb will frost up simple physic's and in a car or truck with a carb it would do the same thing is it was not for the hot air intake off the exhaust manifold. Same thing happens with compressed air. As it is compressed it gets hotter but as you let it back out like with an air blow gun it gets colder and if you where to hold that blow gun at the same place long enough it would also frost up where it was hitting |
| George Marsh
11-11-2012 19:32:59
50.104.246.0
Re: Frosty carb- in reply to old, 11-11-2012 15:19:25
| Old, The energy needed to change a liquid to a gas is called heat of vaporization. Gasoline is like freon, change it's state from a liquid to a gas removes energy from it's surrondings, cold carb, frost. George |
| old
11-12-2012 07:45:47
209.86.226.11
Re: Frosty carb- in reply to George Marsh, 11-11-2012 19:32:59
| I have and always have heard the term atomizing so that is what I use when talking about what and how a carb works so I will keep doing so since that is what I was taught and I learned that 40 plus years ago |
| teddy52food
11-11-2012 18:39:28
184.94.175.179
| I have had air impact wrenches that froze up using them in cold weather . |
| old
11-12-2012 07:51:59
209.86.226.11
Re: Frosty carb- in reply to teddy52food, 11-11-2012 18:39:28
| Yep and that is a combination of problems. #1 you have water in your air system so you need an air dryer. #2 that is also normal since as you decompress air it cools and in doing so yep it can cool to the point of freezing and you can even give your self a frost/freeze burn using compressed air |
| Bruce (VA)
11-11-2012 14:29:51
24.125.80.178
| Make a "carb heater" out of tinfoil to get some manifold heat to the carb. |
| Jock(OR)
11-11-2012 09:59:12
71.216.23.229
| | Frost happens when the air temperature is near freezing, but not much below. Experts will tell you that it can't happen when the air is below freezing, because the moisture will already be frozen. There are two types of carburetor frost, exterior and interior. The exterior frost happens when the cooling effect of the air drawn through the carb chills it enough below freezing that the moisture drawn from the surrounding air condenses on the surface and freezes there. The outside surface of the carb has to be somewhat below freezing for this to happen. Interior frost can happen at a higher temperature than the exterior frost. This is because the air flowing through the venturi cools as it speeds up as it passes through. This draws heat from the air and the surrounding parts of the carb, cooling them below freezing and allowing the ice to build up, sometimes to the point of killing the engine when the carb quits working. The intake manifold is designed to transfer some of the heat from the exhaust manifold to the carburetor to help combat this, but it can't overcome it all the time. The original cast iron carburetors help transfer this heat and hold it better than the pot metal kind. Frost on the outside of the carburetor doesn't affect anything, but it may indicate that the venturi is being exposed to icing conditions. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
