TractorLinks.com
Show Parts for Model:
Re: Curiosity killed the oil pressure?
TheOldHokie
11-11-2012 07:44:14
You still have a ground speed issue and slowing down the tractor by clutching kills your PTO driven pump and with it the tiller. Put the pump on the front and it will work better. Combined with a step down Sherman to reduce ground speed probably quite well.
TOH
Bulldozer
11-11-2012 11:54:46
 Re: Curiosity killed the oil pressure? in reply to TheOldHokie, 11-11-2012 07:44:14
enjoy discussing tillers more than compression springs
this response could have gone under "soundguy" we got off the main subject and started another on tillers.
Read most of the archieves mating Ns and tillers.
Lots of guys want to use the N as a tiller puller, but no cigar.
Agree the best current solution isto mount a hydraulic pump to the nose pully and run line back to a hydraulic motor connected to the tiller right angle gear box with a Sherman to reduce wheel speed.
Someone needs to come to the plate design/build an aftermaket replacement for the Howard to reduce wheel speed and not reduce PTO speed for a direct PTO hook up to a tiller.
