Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Curiosity killed the oil pressure?
Bulldozer
11-11-2012 04:10:22
Viewed to videos on You Tube, yesterday, one 9N and one 8N both using a tiller.
The 9N was going slow probably had a Sherman auxilary transmission
The 8N was going really fast, probably stock setup.
Found a 42" wide tiller with a hydraulic motor
connected to the gear box.
Suppose the total setup would have a hydraulic pump connected to the 8N PTO with hydraulic lines from the pump to the tiller hydraulic motor.
Would this set up work on an 8N?
soundguy
11-12-2012 06:10:35
 Re: Curiosity killed the oil pressure? in reply to Bulldozer, 11-11-2012 04:10:22
again.. with the N ground speed low.. that means you are idling... that means pto speed is slow.. that means your hyd output is low.. that means that hyd tiller is slow.
you've been told muktiple times now that N are not good tilelr machines. there are pretty much 2 trannies that make them a tiller machine. a howard and an everette.
a sherman DOES NOT make them a tiller machine. it slows down the trans AND the pto.
the howard and everette ONLY slow down the ground speed.. NOT the pto.
you seem intent of finding a 1200$ soloution to adding a tiller to an N when it's far cheaper to find a machine suited to use a tiller.. or simply get a plow and disc.
