| Ford 9N, 2N & 8N Discussion Forum |
Topic: Re: 53 Jubilee loses spark. Need troubleshooting help
[Show Entire Topic] [Return to Forum]
| Author |
[Modern View]
| William Fissell
11-10-2012 15:28:04
76.18.178.56
@Soundguyyeah, maybe I wasn;t clear. batt side: 6V no matter what dist side: 6V open, 4.5V closed @ points: 6V open, 0V closed. Points are clearly closing and grounding sorry if I wasn;t clear. Bill |
| Dell (WA)
11-10-2012 16:24:39
97.113.105.165
Re: 53 Jubilee loses spark. Need troubleshooting help in reply to William Fissell, 11-10-2012 15:28:04
| | Fizzy........you write........"dist side: 6V open, 4.5V closed"........yer points when closed are GROUND and you should read ZERO volts. Your points are BURNED and are resistive, therefore you read about 4.5-volts with the points closed. Ittza LAW, Kerchoff's Law. Do I haffta tell you to replace yer BURNED points??? Remember to POLISH the INVISIBLE corrosion from between the new points. Me? I use a clean $1-bill clamped between the closed points and pull. Iff'n yer really cheap, tear a strip from HEAVY brown paper grocery sack and use that. ........Dell, yer self-appointed sparkie-meister |
| William Fissell
11-10-2012 17:54:26
76.18.178.56
Re: 53 Jubilee loses spark. Need troubleshooting help in reply to Dell (WA), 11-10-2012 16:24:39
| | @Dell - thank you! That's what I was thinking.... except... when I put the voltmeter on the 'hot' point, its 6 (open) or zero (closed) so at the points.. they are grounding and not generating a voltage across the closed points. ... so I was trying to decide how 4.5V was getting dissipated in that little length of wire from coil to points. Kirchoff's voltage law: the sum of all potential drops around a closed circuit must sum to zero Kirchoff's current law: the sum of all currents leaving a given node must sum to zero. Sounder: yeah, I couldn;t figger out why I ddn;t have spark either.. "you should have spark" ... I thought so too. What would a bad condenser act like? either a short to ground (no) or... thanks! Bill |
| soundguy
11-10-2012 18:27:26
173.107.64.138
Re: 53 Jubilee loses spark. Need troubleshooting help in reply to William Fissell, 11-10-2012 17:54:26
| | if the condensor was shorted.. it would act like closed points. if condensor was open.. it would let points arc and burn pretty quick. you get some that self heal a bit then die out in a few minutes with warmth..e tc. but it's more rare. run a hot wire to the coil. clean points and regap. use that known good coil. see what you get with just the coil.. forget the dizzy cap.. |
| William Fissell
11-10-2012 18:59:18
76.18.178.56
Re: 53 Jubilee loses spark. Need troubleshooting help in reply to soundguy, 11-10-2012 18:27:26
| | OK, will try again. feel like I did all that - new coil, wire from coil to spark plug, regapped the points and dressed 'em wiht a card... still nada. I am puzzled that it's 4.5V on the dizzy side of the coil and 0V on the points... how could a 6" piece of copper drop 4.5V - it can't!
So, where is the likely resistance "point" - at the dizzy feedthu? thx! |
| soundguy
11-12-2012 06:02:23
107.41.73.143
Re: 53 Jubilee loses spark. Need troubleshooting help in reply to William Fissell, 11-10-2012 18:59:18
| chances are if it's dropping that.. it's a very bad connection somewhere else.. that's why i mentioned using a hot wire as a jumper to the coil. if it still drops 1.5v on other side of coil before dizzy.. that leaves you but one place to look.. at the feedthru.. and wy less likely.. the condensor. |
| soundguy
11-10-2012 15:58:24
173.107.64.138
| | then you should have spark. use a jump wire from bat hot to coil.. and set here and pop points manuall using a piece of wood... |
| [Show Entire Topic]
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
