Yesterday's Tractor Co.
Shop Now View Cart
Order Ford 8N Parts Online
Re: Ford 8N Starting Problem
11-09-2012 12:30:48
I had the exact same issue. Fired up my 8N yesterday & moved it from the barn to the garage to adjust the brakes. When the brakes were done it wouldn"t start. Had good fuel flow but intermittent spark. Did all the checks that were shown in all the responses you received but still no luck. Checked the coil by removing the coil wire from the center of the cap and held it 3/16 above a clean spot on the block; turned the key on & hit the starter; no spark. Checked the ignition switch and it was fine. Then I ran a jumper wire across the terminals of the resister (lift your access lid to the fuel tank and it"s on the firewall above the tool box) and repeated the coil test. Whammo! Spark up the kazoo! Ordered a new resister from Yesterday"s, part number A8NN12250A.
