Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Lubrcant for Installing .040 Sleeves
ZANE
11-09-2012 06:35:01
If you use dry ice you won't need anything to install the sleeves. They will fall in the hole.
I use liquid propane. I just wrap the sleeve in a heavy cloth covering the bottom especially and pour in liquid propane useing a fitting I bought to fill small propane tanks from the BBQ grill size tank. Just turn it upside down and open the valve to direct the flow of liquid propane into the open end of the sleeve till it is good and frosted.
Propane is very combustable so be outside and a long way from any source of ignition. Spark etc.
Zane
Propellant..John,PA
11-09-2012 10:10:46
 Re: Lubrcant for Installing .040 Sleeves in reply to ZANE, 11-09-2012 06:35:01
If you check, most of the aersol paint cans are now using propane for the propellant. John,PA
The Rust-o-leum cans generally have a green marble for the rattle. So, when the can is empty, invert the can and cover with a wrag and poke an ice pick into the bottlm of the can. Careful with the cigars. Then cut out the bottom and retreive the GREEN marble for your chinese checker set. :)
