| Ford 9N, 2N & 8N Discussion Forum |
Topic: Short in breaker plate?
[Return to Forum]
| Author |
[Modern View]
| equeen
11-09-2012 05:14:34
209.102.248.236
52 8N side mount.Someone on forum has mentioned "short in the breaker plate" of distributor. Please explain what/how and how to check for short in breaker plate of distr. Breaker plate screws into distr. Seems to be metal-to-metal contact all around the breaker plate. Points are screwed into breker plate. Seems to be metal-to-metal contact between metal of points and the metal breaker plate - not only with screws, but actual base contact. Thanks for explaining what ya mean. Ya will, won't ya? Smile. |
| equeen
11-09-2012 08:27:40
209.102.248.236
Re: Short in breaker plate? in reply to equeen, 11-09-2012 05:14:34
| | Thanks! I did have a short where the screw goes thru side of distr. Replaced screw, bushing, copper tab - which included a thin piece of paper for insulating inside of distr. Not worth a crap. I put a plastic washer behind the scrap paper and have good voltage to the copper strip. However when I connect the copper tab to the new points (screw) and new condensor - I have no voltage (with points open). Next step is to remove condensor contact to points screw and check again. |
| ZANE
11-09-2012 13:45:00
98.83.76.105
Re: Short in breaker plate? in reply to equeen, 11-09-2012 08:27:40
| ZANE
11-09-2012 06:29:48
98.83.76.105
| | Where the points wire goes through the distributor housing is insulated with a thin piece of paper like insulation that sometimes fails. You can buy what is called a "pig tail" wire that has a lump in it to insulate where it goes through the distributor housing to replace the screw stud and insulation stuff that was original or you can just run a length of wire to the points and put a dab of silicone glue where the wire goes through the distributor housing. The older Ford car distributors that carried points used the "pig tail" Zane |
| JMOR
11-09-2012 05:53:26
72.181.173.171
Re: Short in breaker plate? in reply to John Schmincke, 11-09-2012 05:14:34
| Quoting Removed, click Modern View to seeNot in your side mount distributor. That problem is associated with front mount breaker plate. However, the front mount does have a potential shorting point in its distributor housing (not breaker plate). The insulated screw through the housing wall can deteriorate & short to wall of distributor sometimes. |
| equeen
11-09-2012 18:14:49
209.102.248.236
Re: Short in breaker plate? in reply to JMOR, 11-09-2012 05:53:26
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
