Topic: Re: Ford 8N Starting Problem
[Show Entire Topic] [Return to Forum]
| Author |
[Modern View]
| Royse
11-08-2012 20:36:42
69.36.49.151
I read slow, so let me make sure I follow.
"Clip jumper from hot at starter to clip on other side of tractor for use as needed when needed."
Starter only has power when the solenoid is activated, so I hope you mean from the battery side of the solenoid here.
It may not be necessary at all if you have power to the coil with the key on.
"Points are open on distr." and "NO voltage reading from either coil when wired positive post to side post on distr."
If those two happen at the same time, then yes, you have a short in the distributor.
It could be the feed through the side, or something internal being grounded.
You can isolate that with voltage readings (key on) or with resistance
readings (power off) by unhooking/disconnecting the components in the distributor
until you find the problem. I prefer to use resistance readings and save the battery.
"Please confirm that the coil for a positive ground tractor should receive battery power on the coil's negative post "
Sounds right to me, but it will work either way.
I would probably start by just unhooking the points from the feed through
and see if the terminal on the points is still grounded.
Let us know what you find! |
| equeen
11-09-2012 18:12:35
209.102.248.236
Re: Ford 8N Starting Problem in reply to Royse, 11-08-2012 20:36:42
| | Yes, battery cable to starter side of solenoid at the solenoid. Your comment: "It may not be necessary at all if you have power to the coil with the key on." Excellent point - and I do have power to the coil. You wrote: You can isolate that with voltage readings (key on) or with resistance readings (power off) by unhooking/disconnecting the components in the distributor until you find the problem. Correct - and that's what I'll be working further on when I get time to get back to it. After having identified and solved the problem of short with side feed thru distr, I'll be working with points and condenser. Have I really burned up 3 sets due to short at distr side feed??? Going for 4 I suppose. Thanks. |
| [Show Entire Topic]
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
