Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Curiosity killed the oil pressure?
soundguy
11-08-2012 17:02:37
plunger SHOULD have a flat spot.
is the new spring SHORTER than the old one? if so.. there's where some of the oil pressure went..
post back
Mr. T. Minnesota
11-08-2012 17:11:14
 Re: Curiosity killed the oil pressure? in reply to soundguy, 11-08-2012 17:02:37
SG,
The flat spot is on one side of the dome not at the end!! Shouldn't the dome be a complete dome except at the end/top? Am wondering why the dome is flattened on one side?? The guy that overhauled the engine had not replaced the spring and plunger. Hope I explained it a little better. Appreciate any more thoughts!!
Thanks, Mr. T. Minnesota
soundguy
11-08-2012 17:16:27
 Re: Curiosity killed the oil pressure? in reply to Mr. T. Minnesota, 11-08-2012 17:11:14
and yet...my answer hasn't changed any....
at this point I'll assume you are answer shopping, waiting for one you want to hear.
so I'll leave it at that.
have a goodun'
Mr. T. Minnesota
11-08-2012 17:40:32
 Re: Curiosity killed the oil pressure? in reply to soundguy, 11-08-2012 17:16:27
SG, As to the spring length, it is the same. The tension seemed close to the same also. The spring said it was made in the USA too. The previous pressure was about 25 psi at a cold start and tapered off to about 10 psi. Now it does not get above 20 psi at a cold start and have not run it long enough to determine the hot reading. I do not plan to put in the old spring because the spring was worn where it contacted the plunger as it did on my 2N. A broken spring is not good news.
Thanks for the replies!
Mr. T. Minnesota
mhb@ufe
11-08-2012 17:59:24
 Re: Curiosity killed the oil pressure? in reply to Mr. T. Minnesota, 11-08-2012 17:40:32
The relief valve will set the high pressure at start up but has very little to do with amount the pressure drops when warmed up. That is more to do with bearing clearance and condition of the oil pump itself. If changing the spring lowered your cold start oil pressure the new spring doesn't have as much tension as the old one. I would expect your hot oil pressure to be about the same as it was with the old spring.
Mark
soundguy
11-08-2012 17:53:12
as a test.. stretch the new one a tad and see what happens...
Bulldozer
11-08-2012 17:22:04
OK ,if the plunger is supposed to have a flat spot what is the orientation in the hole?
The flat spot appears to be wear surface!
soundguy
11-08-2012 17:41:18
 Re: Curiosity killed the oil pressure? in reply to Bulldozer, 11-08-2012 17:22:04
go rethink that one for a moment see if it comes to ua.
think about a seat and a free floating plunger with a flat on one side of the needle face. what do you expect happens in that gap.. no matter where it is? ?
Bulldozer
11-08-2012 18:12:37
 Re: Curiosity killed the oil pressure? in reply to soundguy, 11-08-2012 17:41:18
That's a relief don't have to get a replacement plunger, one less thing!
soundguy
11-08-2012 18:30:17
 Re: Curiosity killed the oil pressure? in reply to Bulldozer, 11-08-2012 18:12:37
the flat spot discover happens almost as much as people asking if they can use a roto tiller on their 8n.
Bulldozer
11-08-2012 19:04:40
 Re: Curiosity killed the oil pressure? in reply to soundguy, 11-08-2012 18:30:17
Found a used 42" wide rotor tiller, thinking about hooking it up once get the tractor re assembled.
However, probably takes too much HP.
soundguy
11-09-2012 15:51:22
 Re: Curiosity killed the oil pressure? in reply to Bulldozer, 11-08-2012 19:04:40
laugh!
plenty of hp.
too high of ground speed.
just like we tell the other 3 million people that ask this every spring!
get a plow.
it will plow all day...
Bulldozer
11-10-2012 07:42:52
 Re: Curiosity killed the oil pressure? in reply to soundguy, 11-09-2012 15:51:22
Wont't a disc harlow get the same result as the tiller, except it takes multiple passes??
Saw an 8N with a rotor tiller on You-Tube, recently.
U R correct, looked like drag racing.
soundguy
11-10-2012 13:08:22
 Re: Curiosity killed the oil pressure? in reply to Bulldozer, 11-10-2012 07:42:52
i prefer a disc to a tiller.
you can find a reare howard or everett tranny for a older ford that lets them have a very low ground speed to use a rotovator or trencher.. etc.
Bulldozer
11-11-2012 04:10:22
 Re: Curiosity killed the oil pressure? in reply to soundguy, 11-10-2012 13:08:22
Viewed to videos on You Tube, yesterday, one 9N and one 8N both using a tiller.
The 9N was going slow probably had a Sherman auxilary transmission
The 8N was going really fast, probably stock setup.
Found a 42" wide tiller with a hydraulic motor
connected to the gear box.
Suppose the total setup would have a hydraulic pump connected to the 8N PTO with hydraulic lines from the pump to the tiller hydraulic motor.
Would this set up work on an 8N?
soundguy
11-12-2012 06:10:35
 Re: Curiosity killed the oil pressure? in reply to Bulldozer, 11-11-2012 04:10:22
again.. with the N ground speed low.. that means you are idling... that means pto speed is slow.. that means your hyd output is low.. that means that hyd tiller is slow.
you've been told muktiple times now that N are not good tilelr machines. there are pretty much 2 trannies that make them a tiller machine. a howard and an everette.
a sherman DOES NOT make them a tiller machine. it slows down the trans AND the pto.
the howard and everette ONLY slow down the ground speed.. NOT the pto.
you seem intent of finding a 1200$ soloution to adding a tiller to an N when it's far cheaper to find a machine suited to use a tiller.. or simply get a plow and disc.
mhb@ufe
11-08-2012 17:34:01
The flat spot is there to allow oil flow at all times. The orientation doesn't matter. What is the problem with your oil pressure?
Mark
Bulldozer
11-08-2012 18:08:44
 Re: Curiosity killed the oil pressure? in reply to mhb@ufe, 11-08-2012 17:34:01
My theory is the plugs were fouled so badly, raw gas entered into the oil sump and thined out the oil so much the pump gears would not pick up the oil from the sump.
