TractorLinks.com
Order Ford 8N Parts Online
Re: 8N sleeve
TheOldHokie
11-08-2012 16:15:20
Ford believed the thicker wall sleeves were an improvement over the thin wall sleeves. The block castings were not changed and the official Ford recommendation was to rebore older blocks and fit thick wall sleeves. For a decently equipped automtive machine shop there is zero problem boring out thinwall sleeeves and the block to fit thick wall sleeves. It's actually easier and less work than removing the old sleeves before reboring. That said it will wind up being more expensive than simply replacing the .040 sleeves yourself - probably $25 per hole or more.
TOH
Bulldozer
11-08-2012 16:48:21
 Re: 8N sleeve in reply to TheOldHokie, 11-08-2012 16:15:20
Thank you, TOH, for instilling confidence in going ahead with replacing thin wall steel with thick wall cast iron sleeves.
Just received the thick wall sleeves today from North Carolina.
Good to know that the block configuration did not change from 48 to 52 or maybe even as far back as 39 to 52.
There is a post on this forum in Jan 27,2003
stating,"cast iron offers a porous surface which
holds oil and steel does not."
Therefore cast iron offers better lubrication than steel and as a result less friction, less surface temperature, less heat generation
and more thermal efficiency.
Going to gray cast iron sleeves is defininely an upgrade over steel sleeves.
