TractorLinks.com
Show Parts for Model:
Re: Hub or bearing problem?
Dollar Bill
11-08-2012 16:12:56
Concerned? Maybe a little.
When you get the tractor back home, grab the wheel at the top and rock it side to side while watching the axle/nut. If the hub moves and the axle doesn't the hub is likely worn or you may just luck out by tightening the nut.
Bulldozer
11-08-2012 17:06:43
 Re: Hub or bearing problem? in reply to Dollar Bill, 11-08-2012 16:12:56
Had a bearing chart, once, that showed graphically the ways cup and cone bearings can fail.
The bearing manufactures do not guarantee bearings. There is always some excuse.
Hopefully ,the axle thread is OK and the axle shaft is not gauled from a spun bearing cone
or the hub is OK and is not gauled from a spun bearing cup from either inner or outer bearing.
