Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Order Ford 8N Parts Online
Re: 8N sleeve
Bob Harvey
11-08-2012 13:59:21
I've used a sleeve driver (wacker)for removal only once, no worries about hurting the block unless you are a crappy shot with the sBFH. Then anything can happen!
Bulldozer
11-08-2012 14:33:58
 Re: 8N sleeve in reply to Bob Harvey, 11-08-2012 13:59:21
That gives confidence in using the wacker technique.
Contacted the folks at Advanced Sleeve in Concord,Ohio.. the main concern of going from thin wall to thick wall sleeve is a cracking issue.
Maybe the thicker wall cast grey iron sleeve that went into the 50-52 engines had a modified block compared to earlier years to accomodate the thicker sleeve.
Where the 1950-1952 blocks different than the 1948-1949 blocks and when were the thick wall sleeves introduced?
Also, Advanced Sleeve indicated a press fit lubricate is required when installing the cast gray iron sleeve with a maximum .002" interference fit on a 3.368" OD thick wall sleeve.
