Yesterday's Tractor Co.
Shop Now View Cart
Order Ford 8N Parts Online
Re: '52 8n wont start
Dell (WA)
11-05-2012 21:36:11
KRH/ might gitt lucky and don't need a carb rebuild. I'd try without the rebuild first. It should be intuitively obvious, 5-gals of NEW FRESH hi-octane gas. Why? 'cuz it don't have none of that carb jet cloggin' ethyl alcohol additive. Definitely need to "polish" the invisible corrosion from between the points. I use a clean $1-bill clamped between the points and pull. Iff'n yer really cheap, tear a strip from HEAVY brown paper grocery sack and use that. Definitely, re-charge yer 6-volt battery. Sparkplugs are cheap, recommend NEW AutoLite 435's gapped 0.025". Don't pull yer choke knob until after 2-rumpas. Then a QUICK pull and release the spring loaded choke while still crankin' the engine. ........Dell
