Yesterday's Tractor Co. New Parts for Old Tractors
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Re: Lift questions
[Show Entire Topic]  [Return to Forum]
Hobo,NC
11-05-2012 19:16:00
71.30.78.35
With you hand make sure the control valve is moving at the pump...
If not use a pry bar to make it move.... It may be all you need...
I have had one to stick closed after I spent mega bucks rebuild'n the hydraulics after a pry'n it open its never stuck again....
Unless it continues to stick are if you want a challenge leave IT BE THAT IS IF YOU GET IT TO LOWER I have had some mean ones but always won...... Even cold if you push on the lift arms it should lower... Fore go the jack it will only be in your way (if you go their).... Car ramps will be your friend....
http://ytforums.ytmag.com/viewtopic.php?t=346622&highlight=ramps
When I remove a pump I either jack the tractor up and put it on stands or the way I like to do it izz drive the rear wheels up on car ramps, block the wheels then roll under it and remove the pump no jack needed. You will git a little fluid on ya. When you raise the tractor up that gives you the leverage needed to handle the pump. If you do not jack it up then it’s a fight cuzz you kin not git in the rite position to handle the pump. I usually install the top cover and then install the pump, front of the pump goes up and in over the ears of the PTO support and then the rear of the pump goes up add a bolt or 2 at the front of the pump and use one hand to guide the position lever in and push up on the rear and install a bolt in the rear. I have also got good at install’in the lift cover by myself and it does not really make much difference how I install the parts cept its E-Zee’er on my back to install the lift cover first then the pump “8N ONLY”
Its not bad to install the cover last,,,, install the floor boards,,, set the lift cover on the rear of the tractor,,, straddle the center of the tractor and set the lift cover down “tip use 2 line up studs in the front 2 holes to keep the gasket in place and align the cover’’’ Now that the cover is on stand at the rear and lift up the back of the cover and align the position control rod to the pump,,, set the cover down and nail it….
DO Not stand at the rear of the tractor when check’n for hydraulic operation,,,, a spin’n PTO takes on all comers
http://ytforums.ytmag.com/viewtopic.php?t=357245&highlight=pump
[Reply]   [No Email]
ASEguy
11-06-2012 03:15:32
68.186.162.134
 Re: Lift questions in reply to Hobo,NC, 11-05-2012 19:16:00
Thanks for your input Hobo.
[Reply]  [No Email]
[Show Entire Topic]     [Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
