TractorLinks.com
Order Ford 8N Parts Online
Re: 8N Governor
JCinKY
11-05-2012 15:53:58
So if I understand the function if the gov...crank turns gov, balls ride on plate, as balls get further away gov opens throttle? The balls are the weights and flat spots give intermittent/improper function?
Sure it needs a thorough going through just don't want to miss the small things.
HCooke
11-05-2012 18:03:03
 Re: 8N Governor in reply to JCinKY, 11-05-2012 15:53:58
With the tractor running. Grab the gov to carb rod and open up the carb. The gov should fight you. When you have gov off the tractor. Spin the gear with your fingers and you will sell the gov arm pull back away from where the carb would be.
teddy52food
11-05-2012 17:58:12
As the balls get farther away they CLOSE the throttle.
