Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: Lift questions
11-05-2012 15:47:56
Pretty cold here Rich, lower 30's. Harold, I reluctantly stood on the arms and raised and lowered the control lever and nothing happened. They have moved some though because the chains are looser. Chris and Jesse, When I bought the tractor the lift arms flopped back down after raising w/o the tractor running so I guess that rules out rockshaft binding. So I'm left with Bruce's diagnosis which is a stuck exhaust valve. Bruce, I won't do it halfway, so dropping the pump is in my near future. I suppose after I remove the bolts after the tractor is jacked up I'll just use a floor jack as a buddy to lower it. Thank you for all the replies. The good news out of this is the pump lift cylinder appears to be sealing well. This continues to be a learning experience which is why I enjoy old tractors. Gerard
Bruce (VA)
11-05-2012 17:46:37
 Re: Lift questions in reply to ASEguy, 11-05-2012 15:47:56
As Harold said, it's not a major project. I make it an overnight job because I like to soak the pump. I tried a floor jack once, but it's easier for me to just lay on my back & pull it out.
11-05-2012 19:32:37
 Re: Lift questions in reply to Bruce (VA), 11-05-2012 17:46:37
I agree, it is easier for me just get underneath and remove having a small wood block so it doesn't fall on concrete,When lifting it back in,push up hold it with one hand and place 2 bolts loosely in, crawl out put lever in slot.
2N with 8N motor 8N345567
8N 146710
8N 179555
8N 197904
8N 199000
8N 254079
8N 362039
11-05-2012 18:04:32
I agree that you can get it out and in without a jack. (And I am a upper body weakling.)
11-05-2012 15:54:43
Call me if you have any problems. I've done a couple of these. Can be done easily on a Saturday. No gasket sealer on the bottom gasket. Get a big bucket to drain the oil before you remove the PTO shaft. Good time to look at that seal.
11-06-2012 03:16:30
 Re: Lift questions in reply to HCooke, 11-05-2012 15:54:43
Thanks for the offer Harold.
