Yesterday's Tractor Co. New Parts for Old Tractors
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: 8N Starter Question
[Return to Forum]
jmead9
11-04-2012 16:38:38
209.74.116.166
On a 1950, 8N, 6V, side mount distributor what is
the best way to find out if the starter is bad or
not. It (the starter) is a 6V starter Part
#8N11001ND. About 2 years old.
[Reply]   [No Email]
soundguy
11-05-2012 06:21:06
184.246.215.119
Re: 8N Starter Question in reply to jmead9, 11-04-2012 16:38:38
ditto what bruce and the others said.
check bat and connections..
  [Reply]  [No Email]
Bruce (VA)
11-04-2012 17:30:08
24.125.80.178
now all I get is a "click-click-
click".
That noise is coming from the solenoid, not the starter. The solenoid is making a noise because of low voltage. That is likely caused by:
1. A weak battery (charge it & check it per tip # 49))
2. Dirty grounds/connections (remove the cables & clean the connections)
3. Bad cables or incorrect sized cables (replace them - see tip # 41)
4. Bad ground between the starter & the block. (pull the starter away from the block & clean the mating area - see tip # 36)
If you are confident that you have attended to these likely causes, then jump the solenoid. See tip # 43 before you do that.
  [Reply]  [No Email]
Royse
11-04-2012 16:41:19
69.36.49.151
Re: 8N Starter Question in reply to Beoni, 11-04-2012 16:38:38
What is it doing that makes you think it may be bad?
A lot of times the trouble is just dirty connections, or a sticky bendix.
You can have it tested at any good local starter shop.
  [Reply]  [No Email]
jmead9
11-04-2012 16:49:45
209.74.116.166
Re: 8N Starter Question in reply to Royse, 11-04-2012 16:41:19
The battery is fully charged (about 2 months old) as
I have tested it with my own tester. I just
installed new cables today (bought from this web
site), I have checked all of my grounds and see no
problem there, and now all I get is a "click-click-
click". Prior to installing the new cables (I had
previously put new ones on I bought from a local
parts store) and had a lot of trouble getting good
cranking power.
  [Reply]  [No Email]
old
11-04-2012 18:19:39
209.86.226.34
Re: 8N Starter Question in reply to jmead9, 11-04-2012 16:49:45
The click can be caused by a few problems. #1 a weak battery or a bad battery. A bad solenoid or a bad starter. To test the starter you can jumper around the solenoid as in the 2 bog posts make sure it is out of gear if you do that. If it is a bad solenoid the starter should spin if a bad starter you should get sparks but no engine turn over and same with a weak battery
  [Reply]  [No Email]
DON TX
11-04-2012 17:22:30
76.196.0.42
Make sure you have a good ground thru the mounting surface to the block. Sand it so there is metal to metal and no rust or paint. That is where the grounding point is. You can jump the starter with a battery and cables
( Make sure it is out of gear) by touching one jumper to the big stud on the top front of the starter and ground the other cable to the frame. Make sure it is out of gear.. It should turn the starter. Make sure it is out of gear. It can run over you!! Don't ask me how I know. Good luck.
DON TX
  [Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
