Yesterday's Tractor Co. Same-Day Parts Shipping Available
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: 8N .060 pistons
[Return to Forum]
mhb@ufe
11-04-2012 13:46:51
184.153.187.144
Tearing down 8N449385 and when I got out my sleeve puller kit that I got from TOH the removal bushing was very loose in the bore. I new the tools were okay as this would have been the 3rd engine I used them on. I cleaned off the top of one of the pistons and it was stamped .060. I've never used the welding method to remove sleeves but it looks like a may need to try it on this one. I believe I've read that I need to weld three beads vertical in the sleeve. Is that correct?
Mark
[Reply]   [No Email]
John Smith8N
11-05-2012 15:42:53
75.23.122.73
 Re: 8N .060 pistons in reply to Rob (Wyo), 11-04-2012 13:46:51
Ok, I was assuming you had a puck that had the full OD for the .090 sleeves. That smaller OD wouldn't get it, probably just wedge itself tightly inside.
[Reply]  [No Email]
Ken(Ark)
11-05-2012 15:23:25
173.185.121.12
 Re: 8N .060 pistons in reply to JMOR, 11-04-2012 13:46:51
I have two blocks that have aftermarket sleeves installed , which is not uncommon for a machine shop to have done especially on a thin sleeve blocks during the '60 - '70's .
The O.D. is slightly larger than a .090 sleeve , so removing them would not gain anything and add more work .
[Reply]  [No Email]
TheOldHokie
11-05-2012 12:15:53
108.8.1.116
 Re: 8N .060 pistons in reply to WELL...John,PA, 11-04-2012 13:46:51
John Smith8N said: (quoted from post at 14:37:11 11/05/12) I'm not seeing the problem. I don't have a TOH puller set, but I imagine you're using a stepped hockey puck in the bottom of the sleeve to pull it. The puck does all it's pulling on the outside edge and your OD hasn't changed. Just eyeball the puck on center and pull the oversize sleeve. If you can't see or feel when it's centered, wrap a couple of rounds of duct tape on the puck's smaller id. That should take up the .060 overbore space.
The OD of his "hockey puck" is 3.265 which works for both .040 and .090 wall sleeves. The ID of his old sleeves is 3.187+.060=3.247 and the "puck" will surely slip off center and wedge inside if he tries to use it. I do provide an extra "puck" with 3.365 OD to fit the ..090 wall block bores in the newer kits and that one would work fine since the block bore will keep it centered. Might want to consider "upgrading" Mark - that's one you would have a future use for.
TOH
This post was edited by TheOldHokie at 12:17:29 11/05/12.
[Reply]  [No Email]
mhb@ufe
11-05-2012 12:30:15
184.153.187.144
 Re: 8N .060 pistons in reply to TheOldHokie, 11-05-2012 12:15:53
That's a good thought. I will shoot you an e-mail to order one.
Mark
[Reply]  [No Email]
John Smith8N
11-05-2012 10:37:11
75.23.122.73
 Re: 8N .060 pistons in reply to mhb@ufe, 11-04-2012 13:46:51
[Reply]  [No Email]
mhb@ufe
11-05-2012 11:49:42
184.153.187.144
 Re: 8N .060 pistons in reply to John Smith8N, 11-05-2012 10:37:11
The kit TOH makes uses the same bushing for the thick sleeves and thin sleeves. Because of the sleeves having .030 cut out of them all the way around I would have less than .010 contact all the way around which I don't feel would be enough contact.
Mark
[Reply]  [No Email]
Duner Wi
11-05-2012 09:47:21
216.226.80.242
What I have done is figure out OD of sleeve for a particular engine and then what size pistons were offered for that engine with the OD being the same for all. Now I make steps in the puck so it will fit 1 or 3 different size pistons.
One puck I have fits 3 3/16, 3 1/4 and 3 5/15 pistons.
[Reply]  [No Email]
Hobo,NC
11-04-2012 18:44:09
71.30.78.35
 Re: 8N .060 pistons in reply to HCooke, 11-04-2012 13:46:51
If you are 110% positive it has a sleeve TOH can make you a puck to remove it... If it were me it would go to a machine shop and have them bored it out to be on the safe side... How sure are you it has a sleeve....
[Reply]  [No Email]
mhb@ufe
11-05-2012 04:41:26
184.153.187.144
 Re: 8N .060 pistons in reply to Hobo,NC, 11-04-2012 18:44:09
100% It has thick sleeves that have been bored for .060 pistons which would leave about .060 thick sleeves.I will either try the weld method or have TOH make a new bushing. I'm leaning towards the weld method as I may never use a .060 bushing again.
Mark
[Reply]  [No Email]
Dell (WA)
11-04-2012 14:48:35
97.113.109.211
mhb.........yeah, just scab at least 3-beads top-to-bottom to shrink the sleeve. No LAW sez you can't use 4-or-5 beads. Important thing, don't WELD thru the sleeve. .........welder Dell
[Reply]  [No Email]
mhb@ufe
11-04-2012 14:56:31
184.153.187.144
 Re: 8N .060 pistons in reply to Dell (WA), 11-04-2012 14:48:35
Thanks Dell, the sleeves should still be roughly .060 thickness so it shouldn't be too bad.
Mark
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
