Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: Battery terminal wiring question
Mr. T. Minnesota
11-03-2012 16:02:08
Would do as suggested, flux cable and insert vertically into the connector. Put the heat (torch) to it and melt in the solder. It will take a little solder. I would be hesitant to use the crimping nut- would not trust it in the long run. Thought I was the only one that does as Soundguy does. That technique costs a lot less money!
Hope this helps!
Mr. T. Minnesota
11-03-2012 17:03:47
 Re: Battery terminal wiring question in reply to Mr. T. Minnesota, 11-03-2012 16:02:08
yep.. I'm cheap nowadays witht he bad economy.. have to be.
scrap copper pipe is still pretty easy to come by. pound one side flat.. drill out for bolt.. trim round on end if needed with grinder wheel. stick cable in.. flux.. solder.. usually get solder around the hole too.
never had one fail. virtually ffree ends too.. just a lil gas, flux and solder cost..
