Picture Test
Worked for me. Here's a copy of your tractor picture.
Nice Tractor. Make sure you go to your photo bkt. account setting and make it private. Otherwise your albums are open to the public.Private will only show the pics you post for others to see.
It appears your copying the wrong code. I think that your using the code for direct links when you should be using the one that says "IMG code", which is two lines down.Hope this helps ya out.
Here is the results of using the IMG code
and here are results from using the IMG thumb code
and here are the results using the direct link code
8N
